Edit Rail Path - U shape along the horizontal plane
emodderman
emodderman
OK, so I'm thinking it cannot be done easily but it's been a while since I've investigated so I'll see if someone can confirm!
I'm editing the rail path with a wall extension, so it has a return towards the wall. What I need is another return back in on itself like this:
I can't get it to work but I feel like it should be possible...
so... Possible or no? And would this work with any sort of termination family? What are my options here?
Model a separate railing with only a handrail for the return.
emodderman
Thanks @ToanDN  - I did know I could do it this way, but I hate having separate railings like this as they're always left behind when changes occur. I ended up creating a railing termination that matched the path I needed.  It isn't a perfect solution either, but it looks great and moves with the railing and is flexible size-wise.
