Property Lines
3 REPLIES 3
Julien.Morilhat
1402 Views, 3 Replies
Property Lines
The property line in Revit should have the same behavior that the grid line. You draw the property line in the plan and it appears in section and elevation. Indeed in the world of architectural documentation  we need to show their boundaries in section and elevation.
Furthermore, a porpriety boundary changes sometimes during the project and it will be nice to be able to assign a phase of creation to this property line.
Tags (1)
3 REPLIES 3
PLs in Sections and Elevations?  Phased PLs? Interesting concepts.  Why don't Grid Line work for you?
in reply to: Julien.Morilhat
You can create a mass and override the cut line pattern to match property lines. They are 3d and can be phased.
in reply to: ToanDN
...or a fence.   😉
Forma Design Contest
Technology Administrators
