The property line in Revit should have the same behavior that the grid line. You draw the property line in the plan and it appears in section and elevation. Indeed in the world of architectural documentation we need to show their boundaries in section and elevation.
Furthermore, a porpriety boundary changes sometimes during the project and it will be nice to be able to assign a phase of creation to this property line.
Solved by ToanDN. Go to Solution.
PLs in Sections and Elevations? Phased PLs? Interesting concepts. Why don't Grid Line work for you?
