Properties problem
Properties problem
Properties problem
I created a door tag, and I would like to show the viability optiond in the properties window when selected (as I marked in the picture). Is there any way to do that?
Also, is there a way to make the "Leader Line"  unchecked by default?
Thanks!
Amit
Avaris.
What you did now is creating type parameters, these are managed per type therefore only accesible by opening the type properties. What you want is instance parameters (sorry you have to rebuild these parameters) these are managed through the properties browser in your project environment.
Leader line, as far as I'm aware, cannot be unchecked by default. But when you uncheck it in the top bar (project environment), during that session you will create tags without leader line.
Hi! I can't find how to create instance parameters... Do you know if there is a tutorial for that?
Thanks!
