PROJECT BROWSER DISAPPEARED 2019
10 ANTWORTEN 10
Nachricht 1 von 11
5754 Aufrufe, 10 Antworten
Hi there
My Project Browser has disappeared.
Nothing to do with multiple screens.
Obviously cant do much without it.
Anyone help?
10 ANTWORTEN 10
Nachricht 2 von 11
ennujozlagam
als Antwort auf: Anonymous
hello, go to your user interface and tick. thanks
Nachricht 3 von 11
als Antwort auf: ennujozlagam
No, sorry, its not happening when i tick or untick... got nothing.
Nachricht 4 von 11
Alan.johnson1970
If it is not turned off it must either be obscured by something or docked with properties, or moved to another screen.
AJ.
Nachricht 5 von 11
Sahay_R
als Antwort auf: Alan.johnson1970
@Anonymous it may have moved OFF the screen. Try something from this resource -
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/ENU/Revit-Troubleshooting/files/GUID-686EE716-3DEA-4D84-8DAA-BA09F538B349-htm.html
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 11
als Antwort auf: Sahay_R
Nachricht 7 von 11
RevitRx
if either the project browser or properties box get "stuck" open up the options dialog box (either file or the R button top right depending on the version) and then just click ok. that should reset it. if not, one of the other troubleshooting posts should do it.
www.RevitRx.com
Nachricht 8 von 11
AyoAllCAD
als Antwort auf: RevitRx
After many months of struggling with this problem, I just stumbled across another solution in a different forum.
Go to Control Panel and change your screen magnification to 100%.
  1. Use Control Panel\Ease of Access\Ease of Access Center\Make the computer easier to see
  2. Select Change the Size of text and Icons
  3. Go to Scale and Layout
I use a Microsoft Surface Pro 5 and it was set to 200% to compensate for the 2736 x 1824 recommended Resolution Setting.
Once I changed the settings, the Revit and other windows became smaller and behold, there was the "missing browser" and property pallete
Nachricht 9 von 11
als Antwort auf: AyoAllCAD
This worked for me too! Thanks
Nachricht 10 von 11
aalmeidaA43VF
THANK YOUUU.... This solution worked for me ... in my case it needs to be in 100%
Nachricht 11 von 11
z28commero
Thx for this post - couldnt figure out why mine dissappeared either.  Changing from my original setting of 125% back to 100% made the properties palatte magically appear, then I could change back to 125% and it remained.  Crazy, but thats the only thing that worked - appreciate!
Fyi, it happened when I took my laptop home and hooked up to my home monitors, then brought back to work on my regular monitors.
