PROJECT BROWSER DISAPPEARED 2019
Message 1 of 11
Hi there
My Project Browser has disappeared.
Nothing to do with multiple screens.
Obviously cant do much without it.
Anyone help?
Replies (10)
Message 2 of 11
ennujozlagam
hello, go to your user interface and tick. thanks
Message 3 of 11
No, sorry, its not happening when i tick or untick... got nothing.
Message 4 of 11
Alan.johnson1970
If it is not turned off it must either be obscured by something or docked with properties, or moved to another screen.
AJ.
Message 5 of 11
Sahay_R
@Anonymous it may have moved OFF the screen. Try something from this resource -
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/ENU/Revit-Troubleshooting/files/GUID-686EE716-3DEA-4D84-8DAA-BA09F538B349-htm.html
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 6 of 11
Message 7 of 11
RevitRx
if either the project browser or properties box get "stuck" open up the options dialog box (either file or the R button top right depending on the version) and then just click ok. that should reset it. if not, one of the other troubleshooting posts should do it.
www.RevitRx.com
Message 8 of 11
AyoAllCAD
After many months of struggling with this problem, I just stumbled across another solution in a different forum.
Go to Control Panel and change your screen magnification to 100%.
  1. Use Control Panel\Ease of Access\Ease of Access Center\Make the computer easier to see
  2. Select Change the Size of text and Icons
  3. Go to Scale and Layout
I use a Microsoft Surface Pro 5 and it was set to 200% to compensate for the 2736 x 1824 recommended Resolution Setting.
Once I changed the settings, the Revit and other windows became smaller and behold, there was the "missing browser" and property pallete
Message 9 of 11
This worked for me too! Thanks
Message 10 of 11
aalmeidaA43VF
Observer
Observer
THANK YOUUU.... This solution worked for me ... in my case it needs to be in 100%
Message 11 of 11
z28commero
Thx for this post - couldnt figure out why mine dissappeared either.  Changing from my original setting of 125% back to 100% made the properties palatte magically appear, then I could change back to 125% and it remained.  Crazy, but thats the only thing that worked - appreciate!
Fyi, it happened when I took my laptop home and hooked up to my home monitors, then brought back to work on my regular monitors.
