Linked model invisible
marco.defina
marco.defina
i created a model with a imported dwg file.
I linked in my main model, but i see nothing...Any idea?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
RobDraw
With all of the ways to control visibility and knowing nothing about what you have tried, we will be playing a guessing game. My game starts with the basics but I don't want to be insulting because you are a BIM Manager.
So, why don't you share what you have tried so far?
Rob
Sahay_R
@marco.defina  - go into VG>>Revit Links and make sure that the Display Settings for the linked file are overridden to By Linked View.
PS - on a totally unrelated point - please do not make a habit of importing DWG files into Revit - linking them is a safer option for the health of the model.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
marco.defina
All visibility and filter was flagged, and the 2 files are new with all visibility on, so I thought there was a problem.
So i rechecked all after your message, i found that in visibility options of imported categories of the linked model one layer was turned off, for  an inexplicable reason. I think a misprint of a precedent .dwg with same name in the Template.
I appreciate your sarcasm, but you know, sometimes everyone make a mistakes Smiley Happy. So the solution is yours, have a nice day.
With linked dwg (685mb of ACIS) Revit was extremely slow. By importing in a separate Revit model and then link this model in the main model, i have a normal speed of Revit and i work better.
JML_Mela
Hi!
We have the same problem. We received several dwg's from the architects, as they were just surroundings, we linked them into a revit and then we tried to link that revit to our central file. The problem was that we could not see it unless we reveal the hidden elements. We found the answer you gave to the guy and we tried. It worked, but I would like to understand why and if there is a better way to do it.
Mela
RobDraw
What settings did you use to link the files?
Rob
JML_Mela
Hi!
When you go to the template or if you change to none, in both options, all
linked files are on and as “By host view”, the only layer inside is as “Not
overridden”, If I change it to “By linked view” it works, but I have to do
it in all the templates.
This is in the file where I inserted the linked files:
This is in the file where I Insert the previous file:
Thank you!
