In previous versions, it was possible to select any number of schedules on a sheet, then copy and paste them to the same place on other sheets. In 2022 (only for Keynote Schedules), the Copy button is greyed out, and Ctrl-C/V does nothing. I'm guessing this was either missed or removed due to the new schedule features, but just thought I'd see if perhaps it was something fixable, as I use this frequently. Still works fine for all other schedules.
No like issue here. Can Copy/Paste multiple Keynote Schedules at a time to other Sheets.
Very strange - it looks like it's any keynote legend that was present before the file was upgraded. Starting a clean new file from no template doesn't have any issues, and I can then use Insert View from File to bring over the working legend and replace all the broken ones.
Out of curiosity, I tried reinstalling Revit and it still persists.
If this is the worst bug after upgrading, then I'd say I'm doing alright!
Seems to revolve around the Filer by Sheet parameter - turn that off and the copy/paste option enables, turn it back on and no more copy/paste.
I am getting the same thing. I turn of filter by sheet, then it works. I use key notes all the time. This should be a bug report, this did not happen before the release of 2022.
I thought I was loosing my mind. I use it on hundreds of sheets for years and it was not working (Crtl+c/v). The above suggestion did the trick. For something so basic I believe a response from adesk to this issue should've been very valuable.
Oh boy... That saved my butt today. I thought I was losing my mind as well. Thanks for providing the info on this topic!
Thanks for posting this topic @springerarchi, this saved some valuable troubleshooting time with some of our Revit users today.
