Hi!
I'm trying to configurate materials that look a little transparente, like a voil fabric, but when i open the same family in other versions (Revit 21,22 and 23), the transparency doesn't work unless i leave it very low, like 4%. More than this is opaque.
I've also tried to use a pattern with a cutout, which works perfectly on Revit 2020, but is horrible when open in 2021 and after.
Does anyone know how i can make it look the same in all versions? Is there any settings i can use?
Why don't you use PBR Materials?
Regarding the difference you are seeing between versions, that is due to the enhanced realistic views.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-F8F2FB5E-C4BE-495C-A1B1-DB425A0926A8
