Problem with transparency in materials in Revit versions after 2020
marinaKXNYB
marinaKXNYB
Community Visitor
Community Visitor
Hi!
I'm trying to configurate materials that look a little transparente, like a voil fabric, but when i open the same family in other versions (Revit 21,22 and 23), the transparency doesn't work unless i leave it very low, like 4%. More than this is opaque.
I've also tried to use a pattern with a cutout, which works perfectly on Revit 2020, but is horrible when open in 2021 and after.
Does anyone know how i can make it look the same in all versions? Is there any settings i can use?
vitorbortoncello
Make sure to use the same render appearence path:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
