If you can load the family then it should be able to be used. You might need to figure out what the family expects for a hosting workplane. If you're not sure what category family the bolt is then open the family itself to see what Family Category and Parameters shows for category.
Edit: Steel ribbon tab > Bolts is a Fabrication feature not part of Revit LT, sorry.
Steve Stafford
