Problem with snapping (Rhino object)
2 REPLIES 2
HEIKKI.VUORINEN
1575 Views, 2 Replies
I have created objects in Rhino and imported them to Revit (basic geometry is the same in both). I can snap to the first one but not to the second. What could be the problem?
Labels (2)
2 REPLIES 2
RDAOU
in reply to: HEIKKI.VUORINEN
@HEIKKI.VUORINEN
Export as separate Elements...ie: each as a 3dm >>> then import both into the same family/in-place
Otherwise use a different format than .3dm
  • DWG
  • Or FBX to Formit then Formit to Revit
Alternatively use the Rhino plugin which provide interop Revit and Rhino https://www.rhino3d.com/features/rhino-inside-revit/
HEIKKI.VUORINEN
in reply to: RDAOU
RhinoinsideRevit worked. The reason might have related to the orientation/ortho of the object.
Forma Design Contest
