When I try to render a door in lumion ( consisting of door frame glass sheet ) , Lumion applies 1 material to both the frame & glass. and reads all the door as 1 material . I extracted my model from revit and used a glass door from the families provided in revit . Can someoneplease assist me with that . thanks !!
Did you use the Lumion Plugin or did you simply export as FBX
double check in your door family if they are in different materials?
or refer to this link and see if helps. thanks
