Anyone have a fix or workaround for this?
Revit 2017.1.1 (don't know about other versions)
Transferring Print Standards from one project to another does not update changed settings in Print Setup with the same name.
There is no message about settings with duplicate names. The settings changed in the Print Setup with the same name are not changed.
New Print Setups do transfer.
Solved by alan.quinn. Go to Solution.
Toan Nguyen
Have tried it with and without saving the source project. Same result.
Did you get a different result?
Toan Nguyen
Development is aware of this and it will require a code change to address. In the meantime we suggest checking both file prior to Transfer Project Standards, if you have the same print setting names change one, then transfer.
Thanks for posting.
