Sloped curved roof in Revit 2016
1 ANTWORT 1
Nachricht 1 von 2
btobias
1319 Aufrufe, 1 Antwort
Hello, I am trying to create a curved roof that slopes in 2 directions.  The structural engineers have already designed the framing for this roof so I should be able to get the slope from that.  I'm fairly new to this, can someone help as to how I can create the curved roof, then align it to the slope of the beams in the linked Structural model(or vice versa)?  Thanks in advance!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: btobias
1. If you are not sure if the roof is flat or warped, you could create an in-place mass using the edges of the structure as reference. Then, create a roof by face from the mass.
2. If you are sure the roof is flat, you could create a regular roof by sketching the boundary, then draw the slope arrow at each edge to match the slope from structure.
By the way, if a roof is flat, which I think yours is, then it technically slopes in one direction. You see different slopes on different edges because they are not parallel to each other.
