Point Cloud Reload Visibility
2 REPLIES 2
tdaltd
277 Views, 2 Replies
Working with point clouds.
Going great but project is quite heavy and slowing down beyond workable.
Unloaded the point cloud. but did not remove it.
Worked on the project nicely for a few hours.
Wanted the point cloud back for a rendering so reloaded it.
Point cloud does not appear althrough is says it is loaded.
Checked all visibility and phase settings.
2 REPLIES 2
RDAOU
in reply to: tdaltd
@tdaltd
Did you try to remove it from model then insert again from source folder?
Is it a local file or on the cloud?
How big is it size wise? Split and patch or thin it...point clouds with high LOD tend to cause graphic issues if you are low on resources
Too many variables and any suggestion would be a wild guess without the point cloud to inspect.
in reply to: tdaltd
Maybe you hid it. Have you tried Reveal Hidden Elements?
Forma Design Contest
Technology Administrators
