Can't create void profile
6 ANTWORTEN 6
Nachricht 1 von 7
1620 Aufrufe, 6 Antworten
Every time  I use void sweep tool, the way to create a  profile grey out already. What is the problem dealing with? It's ok when I use normal sweep tool.Capture.PNG
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
It doesn't occur to you that the Select Profile button is available to click? Click on it first.
Nachricht 3 von 7
als Antwort auf: ToanDN
Yep, As u said, it bring like this . There is nothing to load nor sketch a profile.Capture.PNG
Nachricht 4 von 7
It's Ok now!  need to jump another tap.So confusing.Is that really need to be? Why don't bring directly ? Thanks for your answer bro.
Nachricht 5 von 7
Look at the tab.  Click on Modify | Sweep tab.
By the way, you cam always draw a Solid sweep and change it to Void after the fact.
Nachricht 6 von 7
Nachricht 7 von 7
suhruthchaitanya
You're not useful
