Greeting,
I have a question about point cloud coordinate setting. Do you know how to set the coordinate for point cloud before importing to Revit using "shared coordinate"
The reason for that is I want to import Civil 3D file and point cloud in the same coordinate system and compare the difference.
Any help would be appreciate.
You'll need a common coordinate point. Can you readily identify a point in the Point Cloud RCP that is a point in the Civil 3D DWG?
@qchenTPPXV wrote:
Yes, I can. But I like to compare the difference and find out the accuracy for the point cloud that is from the drone map.
You want to compare them in Revit? Well then, insert the Point Cloud into a New Project. Positioning doesn't matter. Then use Specify Coordinates at Point tool and pick that xyz coordinate point in the Point Cloud. Then insert the DWG via Shared Coordinates. The xyz coordinate point in the DWG should be in the exact same location as the xyz coordinate point in the Point Cloud.
