1. Begin by creating a new family with the template called generic model wall based.
2. Double click Placement Side in elevations in project browser.
3. Click Model Text and type any letter you want and then click OK.
4. Place the letter on the wall and then vertically align it to the vertical reference plane.
5. Click the letter, go to properties window, and click the little gray rectangle all the way to the right in the Text field.
6. Click Add Parameter, give it the name "Letter", click Instance on the right and then click OK twice.
If you want to be able to change the height of the text in your project then continue with the following steps. If not, save the family into your desired folder or choose Load into Project. If you save it into a folder then you can load into your project as a component just like you would with furntiure.
7. Click the letter, click Edit Type in your properties window, click the little gray rectangle all the way to the right in the Text Size field.
8. Click Add Parameter, give it the name "Text Height", click Instance on the right and click OK three times.
If you want to be able to change the depth of the text in your project then continue with the following steps. If not, save the family into your desired folder or choose Load Into Project. If you save it to a folder then you can load it into your project as a component.
9. Click the letter, go to properties window, and click the little gray rectangle all the way to the right in the Depth field.
10. Click Add Parameter, give it the name "Text Detph", click instance on the right and click OK twice.
11. Save the family into your desired folder or choose Load into Project.
12. If you haven't created an arced wall in a plan view then do so now.
13. Click Place a Component and place it where you want on the wall.
14. If you want additional letters you simply right click the letter and create similar.
15. Place the letter and then with your new parameter fields in the properties window you can change the letters how you want.
Note: Sometimes the backside of the letters embed into the wall when looking in floor plan view. If you don't like this then you could follow the same steps above, but for the family template called generic model face based. I personally feel the wall based template fits the text on the curved wall better than the face based. Face based seems to place the text tangent to the wall, leaving voids behind the text.
