PDF problem with text
We have encountered a problem all of a sudden, the text and quality of print is distorted. Attached is the error and the screenshot showing how it should print (as preview). Can anyone advise the fix. This is happening in r2020 and r2021. print preview.JPGerror.JPG
Accepted solutions (3)
syman2000
Recent window update cause the text and image to go haywire. You may want to remove one of the windows update. Check this post
https://forums.autodesk.com/t5/revit-architecture-forum/having-text-and-image-issue-when-printing-wi...
michael.coviello
Autodesk Support
Autodesk Support
Hello All,   This article relates to the KB5000802
PDFs are incorrectly printed after installing March 2021 Microsoft Update in Revit
If a problem still exists after this is removed, Please log an Autodesk support ticket.    Thank you.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Thank you so much! Saved the day.
