Pattern component Shadow?
6 REPLIES 6
606 Views, 6 Replies
So I created the following pattern component as my light filter for my design. But the shadow from it looks like a regular orthogonal grid. Only if I select one of the created components, the shadow changes and looks like the actual pattern I made. Is there any way to fix this?
6 REPLIES 6
How does it look if you print to a PDF?
Is it actual geometry?
in reply to: barthbradley
I created a pattern component family, which I then assigned to the dace of a massing element
in reply to: ToanDN
The shadows look right both when I save it as a PDF and when in sheet view.
Then no need to be worried.  Revit just simplifies the shadow graphic on screen to increase performance.
in reply to: ToanDN
Thank you!
Forma Design Contest
Technology Administrators
