[PLEASE HELP] SHEET, SCALE, PRINT, PAGE A0.A2,PDF,
MY Teacher ASK ME TO BUILD A MINI SCALE MODEL WITH CARD BOARD
I FOUND THE PLAN IN IMAGE, I SCALE THE IMAGE IN REVIT
NOW I WANT TO PRINT THE PROJECT BUT I Can't FIND A PAGE[ A0 ]FORMAT THAT CAN FIT THE PLAN
SCALE 1:25 - HIGEST POINT IS 179 FEET
I WANT THE SCALE IN THE PAPER AFTER PRINT TO BE 1:25 IN ORDER TO MEASURE IT WITH A SCALE RULES AND TO BUILD MY MINI SCALED MODEL!!!!!!!
SO MY PROJECT Can't FIT INSIDE ANY TITLE BLOCK
I'm a little confused. Are you placing the Image directly on the Sheet? Not in a View and then placing the View on the Sheet?
If the Image is being placed directly on the Sheet, you need to Scale the Image itself. The View Scale and Crop have nothing to with it.
1:25 scaled model of a 179' height building is over 7' tall, not mini a all. If the information you have provided is coorect then you need to print the 1:25 drawing to several sheets and glue them together to build the cardboard model from.
But somehow, I think either the requirements from your teacher are incorrect, or you misunderstood it and rephrased it incorrectly here.
