Pattern component Shadow?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
718 Aufrufe, 6 Antworten
So I created the following pattern component as my light filter for my design. But the shadow from it looks like a regular orthogonal grid. Only if I select one of the created components, the shadow changes and looks like the actual pattern I made. Is there any way to fix this?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
How does it look if you print to a PDF?
Nachricht 3 von 7
Is it actual geometry?
Nachricht 4 von 7
als Antwort auf: barthbradley
I created a pattern component family, which I then assigned to the dace of a massing element
Nachricht 5 von 7
als Antwort auf: ToanDN
The shadows look right both when I save it as a PDF and when in sheet view.
Nachricht 6 von 7
Then no need to be worried.  Revit just simplifies the shadow graphic on screen to increase performance.
Nachricht 7 von 7
Thank you!
