Solved by ToanDN. Go to Solution.
The real problem is that without option, I can't start Label Contours with closed numbers. Any idea to solve this problem? (In photo, look at the primary contours. There are not closed numbers)
Contour elevations are relative to the Elevation Base. You could use a Relative Base.
....just to be clear; by "closed" you mean whole numbers? If so, why not raise the Elevation Base 0.30 or lower the Toposolid 0.30?
Under the Type Properties of the Contour Labels.
But, if those numbers are still not whole numbers when choosing a different Elevation Base, then you need to move the Toposolid down until it zeros out (e.g. 0.30 down if the Elevation Base is unchanged from the one used in the above screenshot). Or, like I said, move the Elevation Base up 0.30 in this case.
The result is the same but with different numbers, they don't changes to whole numbers. Neither the contour label does not change even when I move the toposolid. The reference is always +0.30
That doesn't make any sense unless your Contour Display values (under the Properties of the Toposolid) are not whole numbers.
Post you Project File and I'll look at it and see what's going on.
Use Survey Point for Elevation Base, then move the CLIPPED Survey Point up or down in Elevation.
But I already defined the toposolid with real geoposition an altitude using the Survey Point. The logical thing would be to show curves with closed numbers, right? Define label conturs like the previous Passing Through Elevation setting at least. Contour display control is setting on -100, 1000.
Is the base of the Toposolid on the Survey Point ORIGIN? Go to Elevation, Unclip the Survey Point and enter 0,0,0 into its x,y,z Coordinates, Isolate the Survey Point and Toposolid in the View and zoom in on the base of the Toposolid at and Survey Point/Origin. I'm betting the Toposolid Base is not intersecting with the Survey Point Origin, but slightly above it.
Or, if you just want to fake until you make it, change the formatting. 😉
Change Inicio to 100.20.
