Passing Through Elevation on Revit 2024
JOESQUEDAC
Message 1 of 22
JOESQUEDAC
Hi. I'm looking for the Passing Through Elevation on Revit 2024. Previous versions has the option on Toposurface settings, but now there is no option to configurate passing elevation through en Toposolid settings on Revit 2024. Can help me?
Replies (21)
Message 2 of 22
Message 3 of 22
JOESQUEDAC
Yes, but I need the Passing through elevation settingCaptura de pantalla 2023-12-04 104420.png
Message 4 of 22
That dialog box doesn't exist in 2024.
Message 5 of 22
Message 6 of 22
JOESQUEDAC
The real problem is that without option, I can't start Label Contours with closed numbers. Any idea to solve this problem? (In photo, look at the primary contours. There are not closed numbers)
Message 7 of 22
Contour elevations are relative to the Elevation Base.  You could use a Relative Base.
....just to be clear; by "closed" you mean whole numbers?  If so, why not raise the Elevation Base 0.30 or lower the Toposolid 0.30?
Message 8 of 22
JOESQUEDAC
Where is the Elevation Base option?
Message 9 of 22
JOESQUEDAC
Yes, I mean whole numbers, but where is the Elevation Base option?
Message 10 of 22
Under the Type Properties of the Contour Labels.
But, if those numbers are still not whole numbers when choosing a different Elevation Base, then you need to move the Toposolid down until it zeros out (e.g. 0.30 down if the Elevation Base is unchanged from the one used in the above screenshot).  Or, like I said, move the Elevation Base up 0.30 in this case.
Message 11 of 22
JOESQUEDAC
The result is the same but with different numbers, they don't changes to whole numbers. Neither the contour label does not change even when I move the toposolid. The reference is always +0.30
Message 12 of 22
That doesn't make any sense unless your Contour Display values (under the Properties of the Toposolid) are not whole numbers.
Post you Project File and I'll look at it and see what's going on.
Message 13 of 22
Use Survey Point for Elevation Base, then move the CLIPPED Survey Point up or down in Elevation.
Message 14 of 22
Edit Toposolid type > Edit Contour Display.
Message 15 of 22
JOESQUEDAC
But I already defined the toposolid with real geoposition an altitude using the Survey Point. The logical thing would be to show curves with closed numbers, right? Define label conturs like the previous Passing Through Elevation setting at least. Contour display control is setting on -100, 1000.
Message 16 of 22
Is the base of the Toposolid on the Survey Point ORIGIN?  Go to Elevation, Unclip the Survey Point and enter 0,0,0 into its x,y,z Coordinates, Isolate the Survey Point and Toposolid in the View and zoom in on the base of the Toposolid at and Survey Point/Origin.  I'm betting the Toposolid Base is not intersecting with the Survey Point Origin, but slightly above it.
Message 17 of 22
JOESQUEDAC
No becuase my physical reference point is 1.00 m over the ground. I tried moving up and down first the toposolid, after the survey point but the result is always the same: primary contours show decimals
Message 18 of 22
Just post your RVT here.  That's the quickest way to resolve.
Message 19 of 22
Or, if you just want to fake until you make it, change the formatting. 😉
Message 20 of 22
Change Inicio to 100.20.
