Opposite Elevations showing the same
12 REPLIES 12
Message 1 of 13
AutoDidi
457 Views, 12 Replies
The north elevation of my model is showing the same as the south elevation. Please help.
Didi
12 REPLIES 12
Message 2 of 13
ennujozlagam
in reply to: AutoDidi
post some screenshot to see what is your issue?
Message 3 of 13
AutoDidi
in reply to: ennujozlagam
Didi
Message 4 of 13
Alfredo_Medina
Most likely the elevation markers are not located properly in relation to the building, or that their cut plane (the blue line that appears when you click on the tip of the triangle for each elevation marker) is not where it should be.
Another possibility is that one of these views is simply a duplicate of the other, with a different name, using, of course, the same elevation marker.
Message 5 of 13
I agree with what @Alfredo_Medina said.
Maybe post the model.
Message 6 of 13
handjonathan
Hi @AutoDidi
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Alfredo_Medina helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 7 of 13
AutoDidi
in reply to: handjonathan
I cannot figure out what to do
Didi
Message 8 of 13
Alfredo_Medina
What if you simply delete the duplicated view and create a new elevation?
Message 9 of 13
AutoDidi
in reply to: Alfredo_Medina
I deleted the north and south elevations and put in new one and yet the problem remains
Didi
Message 10 of 13
AutoDidi
I still have not had an acceptable reply. Please help.
Didi
Message 11 of 13
Post a copy of the model, for investigation.
Message 12 of 13
I have made the model small purging out unnecessary elements.
Didi
Message 13 of 13
Alfredo_Medina
That file seems to be corrupt, and that might be causing the problem since you already tried the ideas for solution that we mentioned here but that didn't work.
When I tried to open the file, Revit said: "Improper argument" (or similar).
If the model is not too advanced now, maybe you can copy-paste the elements into a new project that has levels at the same elevation, and continue your work in that new model.
Forma Design Contest
Technology Administrators
