No Project in R2023.1 Autodesk Docs
2 REPLIES 2
craig
215 Views, 2 Replies
I've been using R2022 with an external team to collaborate on a Revit model in BIM360. When I click on Autodesk Docs in R2022, the team and project names appear at the top of the window and the Revit model file below it opens as expected. I just installed R2023 and logged into the same account as R2022. When I click on Autodesk Docs in R2023 I get the message "There are no products in this Autodesk Doc account yet." Shouldn't I be able to see those R2022 projects here?
Labels (1)
2 REPLIES 2
in reply to: craig
You need to go to Autodesk Docs (web) and upgrade your projects from 2022 to 2023 to see them in Revit 2023.
craig
in reply to: craig
Yea, They just granted me access to a new project on R2023 and it appeared as it should. Thanks.
Forma Design Contest
