Locking down adjusted wall sweeps
0 ANTWORTEN 0
Nachricht 1 von 1
ZDCMapp
111 Aufrufe, 0 Antworten
Is there a way to keep an adjusted wall sweep from reverting back to the entire wall when the wall is copied and moved? The issue I am having is when I spend all this time creating adjusted wall sweeps for different architectural design elements on a building and I copy, for example, an entire corner of an apartment building to use it on another part of said building design because it is identical, all the adjusted wall sweeps revert back to spanning the entire wall.
This is what it would look like with all the adjusted wall sweeps. I'm using 2 different colored wall sweeps and if you don't adjust them you get the vibration effect in Enscape which occurs when objects overlap each other. I am drawing this building as it's own file to bring into another drawing file which eventually be the entire project of other buildings, roads, parking lots, topography, etc.
I have tried locking the vertical sweeps to the horizontal sweeps but that didn't work. I have a bad feeling that once I copy and paste the building into the topography that all my sweeps will bust and I have many sweeps on the building. MANY. Hope it makes sense as to what I am asking.
0 ANTWORTEN 0
