In-place mass don't room bounding
4 REPLIES 4
murodesign
225 Views, 4 Replies
I'd really like help with the following: I modeled existing irregular stone walls with in-place mass. And now the areas/rooms don't work, probably because Revit doesn't recognize them as room bounding elements. Is there any solution, to obtain areas and volumes like with wall tool? Because... lot of work already done...
4 REPLIES 4
Room boundary lines, or make sure that all walls have the room boundaries parameter checked on
Thanks, but the question is that i don't have walls. I thought create a room bounding parameter in the mass objects, but didn't see how.  I'm not any expert, though...
Although separations lines did work, it sounds unproductive picking the same lines each time i need interact with these "walls"...
you have an unique type of wall, maybe it works if you Create In place walls
for more info:
 https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-76C3DD1C-AF0F-4132-84F0-04B989B5A6F2
Thanks, i thought use in-place with wall category, and i'm a beginner with mass, but i finded this tool more versatile, reference points are very useful. Maybe the result don't difer too much, but i think was faster. Maybe model it all again will take more time than creating separation room lines. But sure i'll consider next time, while don't figure out a way of make mass room bounding.
Forma Design Contest
Technology Administrators
