Multi Language documents
3 REPLIES 3
1004 Views, 3 Replies
I have a client requesting project documentation in two languages.  Multiple languages are now becoming a standard practice for client reviews and approvals.  We are using Revit base platforms (Arch, Structural, and MEP) for all disciplines.  Is there an English translation into other languages?
3 REPLIES 3
ryan.duell
Unfortunately there is no built-in approach within the application to achieve this; it would need to be manually translated \ pasted into Revit.  This has been requested at a few resources which I have included below:
http://www.revitforum.org/showthread.php/962-All-Verticals-Translate-all-Revit-Text-or-labels-in-the...projects
There are some third-party solutions, one of which I have included a link for from IMAGINiT:
http://store.imaginit.com/%2FIMAGINiT-Utilities-for-Revit-2012-StandAlone-P19.aspx
Thank you,
Ryan Duell
in reply to: ryan.duell
Thanks for your response.
Alfredo_Medina
Language translation of technical documents should be made by a translator, a human, not by an automatic machine-translator such as Google. The idea of Google Translate is to give you a quick and rough idea of the context of something that you found on the internet, but do not ever, ever, think of using that to translate a serious document that you are going to present to others, such as the technical information contained in an architectural or engineering project. I would not mark the above response as a solution.
Forma Design Contest
Technology Administrators
