I'm trying to move an element in plan view to align with a nearby element. When moving the element it only allows me to constrain movement to X and Y axis, therefore if it is a small distance it aligns moving in the Y direction when I want it to align moving in the X direction.
Is there a way to set the constraint to a single axis?
In SketchUP you can use the arrow keys to lock the constraint to any axis. Is this not possible in Revit?
Thank you.
