Was working in rvt file but for some reason it turned into an rte file.
1. Does it make a difference?
2. If so how do I turn it back to an Rvt file?
3. What is rte file for?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
This Google is crazyass wicked cool! Look what else I found in 0.23 nanoseconds:
Yes.
Save and close the RTE. Start a new Project and choose From Template then browse to the RTE. Save the new project and it is your working file from now on.
Revit Project Template.
You always use an RTE. Architectural, Construction, Structural, Mechanical are all RTEs
...Revit uses Templates in Families as well. When you create a new family, Revit prompts you to select the Template to use. Generic Model, Generic Model Face Based, Generic Model Wall Based etc. are all Templates.
@JKspace424 wrote:
Thanks for the answers. What are the benefits of using rte file?
RTEs are Revit Project Template files. When you start a new project you can choose from one of the pre-existing RTEs and inherit everything in that template. Revit comes with a few ones such as shown below:
"IFC metric template.rte" doesn't exist.
You already have "Metric Template.rte", as it is installed by default.
@rudy.delacruz wrote:Please,
I want that send me file IFC Metric Template.rte
THX
Rudy
