Move project to origin point
Message 1 of 99
I am having issues with my template for few months and I can't find the cause of the problem.
I am coming from the thread below
https://forums.autodesk.com/t5/revit-architecture-forum/template-corrupted-with-graphic-issues/td-p/...
Today, I have learn that apart of the project base point, and survey point, the revit files have also a origin point hidden. I thought that the 20km rule was between the model and the project base point, but apparently it is between the origin point of the revit file, and the model (I don't know if it is different rule, I had just misunderstood the rule at the beginning).
I have seen the issue with the hatch contour is resolved once you move the hatch close to the origin point (It was already in the project base point, but the project base point was like 12km away of the origin point), so in order to make another test and see if that is the cause of all the problems in the template, I want to move the whole project, model, details, everything, close to the origin.
Does anybody know how to do it? how to move a model close the origin point??
Regards
Replies (98)
Message 41 of 99
SteveKStafford
It seems to me that the issue at hand is our understanding of the Survey Point and Project Base Point Graphic symbol and the notion of points. I've written it several times but it doesn't seem to be understood.
The SP and PBP are not Points in and of themselves, they mark a location. They either mark the origin of their corresponding coordinate systems or they identify alternate spot coordinates relative to their own systems.
I wrote earlier: "Imagine a sheet of graph paper, sketch a PBP symbol at a grid intersection. if you could grab the PBP symbol, while the PBP is clipped, moving it also moves the graph paper with it. In contrast, moving it unclipped changes where PBP symbol rests on the graph papear, the graph paper doesn't move."
This is incredibly important. As soon as you unclip either SP or PBP you change its nature. It no longer is anchored to the origin/location it identifies. It become "loose", free to travel on the coordinate system to mark any location...without moving the coordinate system too.
Like you described in your earlier steps, what happens with your described process is you shift the PBP and the coordinate system over. Then you sever its anchor relationship to the coordinate system when you unclip it to move it again.
It is easy to think of the SP and PBP as points. They do identify points in space, but they aren't moving those points when they are unclipped. Unclipping and then clipping again does not change anything other than tell Revit you want the symbol to be anchored to the coordinate system again. If you move it clipped now it will change the PBP and its coordinate system together.
Steve Stafford
Message 42 of 99
@Anonymous wrote:
I can only offer empirical evidence to support my assertion that the “invisible point” (e.g. the one that is recognized by Revit as “THE ORIGIN” when you Link in “Auto-Origin to Origin”) – CAN be moved.
Can you open his file and move the “invisible point” aka “THE ORIGIN”, to his building so he wouldn't have to move the building back to that point?
Message 43 of 99
Really @ToanDN, you need to stop with the sarcasm. If you seriously believe that's what I'm saying, that would explain the subsequent tug of war. Sorry to say, but you just plainly misunderstood me.
My initial post that you jumped all over me about was stating that the “origin point” could be moved. If you follow the workflow I posted today, you’ll undoubtedly understand where I am coming from. If you care to share back a professional comment or two about the workflow or my suppositions; I’d love to hear them.
Thank you,
Barth
Message 44 of 99
That was a professional inquiry for you to prove everyone wrong by moving the Origin to the building in his Revit file. How is that sarcastic?
Message 45 of 99
@SteveKStafford: I agree with everything you said, and I believe we share the same understanding of the Project Base Point and the Survey Point.
I’m not sure where you think we differ. It seems you are emphasizing some of the same points you made to me before, but I don’t know why.
Maybe it’s just semantics. Can I ask you how you would describe what is happening in the workflow I provided?  I can’t think of another way to describe it, other than: “the Startup Location is moved”.  Nor, can I think of another conclusion I could come to that would explain the Startup Location is being recognized by Revit as the Project’s “Origin” when Linking “Auto-Origin to Origin”.
Thank you again for your time.
Barth
Message 46 of 99
@ToanDN: Post a Screencast of how that could be done. I have no idea. I never suggested it.
BTW: Are you being sarcastic when you ask "How is that sarcastic?"
 Smiley Happy
Message 47 of 99
I cannot. It cannot be done. The Origin cannot be moved closer to the building, only the building *can* be moved to it. If it were to be, RADAOU wouldn't need to write his elaborated articles explaining how important it is to model within the 20 mile limit.
Message 48 of 99
Yep, that was one of @RDAOU's best. He lives on despite being gone. Maybe he'll get this and know we miss him and his Ninja Avatar.
Message 49 of 99
SteveKStafford
Your step #5 - The entire Project Coordinate system appears to be shifted over to 50,50 but it hasn't really moved. The survey point and the shared coordinate system has just been left behind at its original location. Remember both coordinate systems are separate, not physically connected at all.
Your step #7 - The Shared Coordinate system is not changed by -50,-50 because the Survey Point was moved unclipped. It's loses its anchor to the coordinate plane in that state. It just move to mark the coordinate location -50,-50.
Your step #15 - This isn't as significant as you regard it. The Project Coordinate system "origin" is still at the so called "50,50" spot, but it's really 0,0. It appears to be 50,50 because the Shared Coordinate system origin is where it started out to begin with. The Project Base Point has this unfortunate behavior of reporting its distance from the Shared Coordinate origin. At this stage in your exercise all that's been accomplished is that the shared coordinate system is offset by 50,50 from the Project Coordinate system origin. It hasn't really moved at all.
I keep harping on the distinct difference between the Survey Point and Project Base Point and their related coordinate systems because no matter how I write about it you keep failing to see the distinction between your clipped and unclipped actions. At least that's how it appears to me. Your steps haven't changed but you're seeing something that isn't happening.
Steve Stafford
Message 50 of 99
Hello @barthbradley I still thinking that the origin point can't be moved, you just move everything around it.
I do not have a big knowledge about this topic, but for what I have been testing, I couldn't find the way to move it.
Otherwise, could you explain me how to do it, using my building as a example. That is the origin of all my problems, the model is far away for the origin, so to resolve it, I either move the origin the building, or the building to the origin. The less painfull would be the origin to the building but I can't find the way to do it.
Regards
Message 51 of 99
Ilic.Andrej
All this mess just about coordinate systems...
This is why its interesting just to see the workflow that the programmers predicted. I assume that for this, Autodesk Knowledge Network is the most reliable source of information:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 52 of 99
SteveKStafford
@Ilic.Andrej The portion of the thread I've been addressing with @barthbradley deals with the subtle relationships of the Survey Point and Project Base Point and their corresponding coordinate systems.
Mostly it is off topic for @Anonymous's issue, except that his company's template was altered in such a way that some of their existing projects are very far from Revit's project origin. They are experiencing the negative symptoms that accompany that situation. He is faced with moving the model closer to the project origin to alleviate it.
It isn't that they didn't follow the recommendations in the help documentation. It's that someone moved the symbols very far from the origin while unclipped which led people to create their models at their location, unaware that they've been shifted far from their home, so to speak.
Steve Stafford
Message 53 of 99
Ilic.Andrej
The David said that he just recently found out that there is an internal origin. This may conclude that they didn't read help (it ain't a crime ofc...). My guess is that its a good place to start. It may be of use to him for future projects.
Btw, when I said mess, I men't mess created by Revit creators... Please, don't get me wrong.
Andrej Ilić
MSc Arch
Message 54 of 99
@Ilic.Andrej I do read the help page and forum, but as I have never had this problem, I never went deep into the topic.
But to be honest, I have an external company and the Autodesk development team reviewing the file for nearly two month, and they can't find what the issue is neither. they always mention about survey point, and project base point, but never about origin point, so it might not be that obvious.
I have just realized about this origin point, and I guess it is the cause of my problems, but I can prove it yet.
Message 55 of 99
Ilic.Andrej
Ok, ofc by "read help", I meant "missed this help topic", as well as
....I have to be careful what I say around here 🙂
I like some Revit features, but I use it cause I have to. Sometimes I get disappointed. Even if it had to be programmed this way, at least they could have mark the internal origin.  People would not be confused....
Andrej Ilić
MSc Arch
Message 56 of 99
@Ilic.Andrej do not worry, I didn't take you wrong.
I just mean I can't read and know everything before use it, and usually, when you have the issue is when you research about the topic. Obviously I don't consider myself as an expert.
But yes, I agree with you, If they make the internal origin point visible, more people will appreciate about how important it is
Message 57 of 99
FAIR59
PointRel.JPGYou can "read" the internal coordinates. Make a spot-coordinate with value Relative for the Coordinate Origin parameter.
Message 58 of 99
@SteveKStafford: You sound frustrated when you say that you “keep harping on” – and, I “keep failing”.  Sorry that it appears that way to you. As Strother Martin said in the movie Cool Hand Luke; “what we’ve got here is failure to communicate”. The fact that I’m talking “Local Coordinates” and you’re talking “Shared Coordinates” in your critique of my workflow, seems to evidence that we’re not on the same page. So, let’s not judge. I think we both have a high-level understanding of Revit Coordinate Systems – we just communicate it differently (albeit, you’re the more accomplished communicator).
In closing, I’d like to refer you to this link, which speaks to the point I was making when I made the statement:  “You can move the Revit Project "WCS" Origin and later find it by Linking a CAD Origin to Origin.”
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/d2b6bd89-3652-4dc1-a9ff-a5c6e550ccd5.html
I remain a big fan of yours,
Barth
Message 59 of 99
Regards
@Anonymous: Your model is over 950 miles away from the internal origin point, and this relationship is maintained even if you “zero-out” all your points. Any suggestions I would have, would be right in-line with what @ToanDN has already suggested.  I feel for you though. You’ve built a wonderful model, and I suspect the “full-version” of it, contains a whole bunch of views, sheets, dimensions, etc. It is going to require a lot of work to rebuild it. The upside is (and you’ll hate hearing this); you’ll never allow this mistake to happen again.
Best of luck to you,
Barth
Message 60 of 99
If your statement reads : “You can move the Revit Project Base Point and Survey Point away from the "WCS" Origin and later find the Origin by Linking a CAD Origin to Origin.” then everyone is on the same page.
