Hi, When I move an element I lose some annotation and I should check all floor plans and put the dimensions again. How could I prevent this issue? Thanks
it may relate to your crop annotation region
in the view turn on all the options for Crop Region in the properties and select the crop region then adjust the dashed outside region
this controls all the annotation in your view
another thing to check is if you are using Leaders for the particular Annotation
What kind of annotation are we talking? Tags need to be close to the objects they are tagging otherwise they will lose the connection. Text notes would need you to adjust the leader arrow. When you move elements, it would help if you move the annotations along with them.
When activating the Move tool, do you have Disjoin checked?
If so, this will cause you to lose the dimensions and tags.
