- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
I am having issues with my template for few months and I can't find the cause of the problem.
I am coming from the thread below
Today, I have learn that apart of the project base point, and survey point, the revit files have also a origin point hidden. I thought that the 20km rule was between the model and the project base point, but apparently it is between the origin point of the revit file, and the model (I don't know if it is different rule, I had just misunderstood the rule at the beginning).
I have seen the issue with the hatch contour is resolved once you move the hatch close to the origin point (It was already in the project base point, but the project base point was like 12km away of the origin point), so in order to make another test and see if that is the cause of all the problems in the template, I want to move the whole project, model, details, everything, close to the origin.
Does anybody know how to do it? how to move a model close the origin point??
Regards
Gelöst! Gehe zur Lösung
