is there a way to make staires like this:
I only managed to obtain this in Revit:
As pictured above, I need to insert four treads at the stairs beginning???
Solved by PijPiwo. Go to Solution.
Thank you so much!
One more thing,......I see a small arc in 3D at the center or the first four treads! Is there a way to adjust it?? It is not visible in Plan view, all the lines (treads) intersect at the same point!!!
I don’t think there is a way around it, at least not that I know of, other than workaround like applying the treads to the stairs, that however, will give you tread lines on the sides.
