Monolithic semi-spiral stairs
6 REPLIES 6
703 Views, 6 Replies
is there a way to make staires like this:
I only managed to obtain this in Revit:
As pictured above, I need to insert four treads at the stairs beginning???
6 REPLIES 6
PijPiwo
Convert component stair to sketch and draw your winders, or create entire stair by sketch.
in reply to: PijPiwo
Thank you so much!
One more thing,......I see a small arc in 3D at the center or the first four treads! Is there a way to adjust it?? It is not visible in Plan view, all the lines (treads) intersect at the same point!!!
PijPiwo
Can you copy your stair to a new project and upload?
here is the attached model.........
Thanks!
PijPiwo
I don’t think there is a way around it, at least not that I know of, other than workaround like applying the treads to the stairs, that however, will give you tread lines on the sides.
Thank you for your time!!!!!!
Forma Design Contest
