Monolithic semi-spiral stairs
6 REPLIES 6
631 Views, 6 Replies
is there a way to make staires like this:
I only managed to obtain this in Revit:
As pictured above, I need to insert four treads at the stairs beginning???
6 REPLIES 6
PijPiwo
Convert component stair to sketch and draw your winders, or create entire stair by sketch.
in reply to: PijPiwo
Thank you so much!
One more thing,......I see a small arc in 3D at the center or the first four treads! Is there a way to adjust it?? It is not visible in Plan view, all the lines (treads) intersect at the same point!!!
PijPiwo
Can you copy your stair to a new project and upload?
here is the attached model.........
Thanks!
PijPiwo
I don’t think there is a way around it, at least not that I know of, other than workaround like applying the treads to the stairs, that however, will give you tread lines on the sides.
Thank you for your time!!!!!!
Forma Design Contest
Technology Administrators
