Missing Keynotes TXT file
mhaeri
Message 1 of 22
mhaeri
i inherited a revit 2018 model from another architect, they have used Keynotes in the drawings but did not include the appropriate text file. is there anyway I can clean the keynotes and start new? without the original txt files I can't edit the notes.
Replies (21)
Message 2 of 22
No. But, you won't lose any that are placed either. You just can't pull new ones from the same file.
...just to be clear, you can edit the existing tags to pull data from a different file, if that is what you meant.  Just don't smoke while doing so.
Message 3 of 22
mhaeri
That is not what I was hoping 🙂
We need to be able to modify notes, spelling, directions, ETC. In my opinion this needs to improve
Message 4 of 22
You cannot modify what you don't have. Ask them for the keynote file.
Message 5 of 22
What would be improved?  were you provided the text file with the rvt?  if so, load it. If not, there's not much in the way of programming that can mitigate that.
Message 6 of 22
mhaeri
No the txt file was not provided. The title of my question is “missing txt file” otherwise there would be no issue
Message 7 of 22
mhaeri
The other Architect is not responding.
Message 8 of 22
Then you need to export a full keynote legend to excel and re-format it to create a keynote txt file.
Message 9 of 22
mhaeri
Thanks, I will try that next
Message 10 of 22
Yes, I understand the issue. You don't have the source file from which the current keynotes were derived. So, you have several choices.
1. Leave the current keynotes as-is.
2. Replace the current keynotes with keynote from your own file.
3. Get the original keynote file that the current keynotes were pulled from.
That's about the size of it.
FWIW: Keynote Manager is the simple, efficient way to edit Revit's keynote files.  I highly recommended it.
https://apps.autodesk.com/RVT/en/Detail/Index?id=604656466920293522
Message 11 of 22
mhaeri
Thank you. I am in the process of retyping the notes and replacing the txt file.
Thanks for your response.
Message 12 of 22
You're welcome.
Message 13 of 22
jimbell153
Open the list in Legends, and open Keynote Legend.
With it open, Go to File>Export>Reports>Keynote Legend.txt
The you can edit the text file, save it in the project Revit Folder and navigate to it
in the Annotate tab>Keynotes>Keynote Settings.
And Bob's your uncle.
Message 14 of 22
jimbell153
Message 15 of 22
MiWolff
Am I right in thinking this only works for keynotes that are already tagged somewhere?
Message 16 of 22
MiWolff
For now, the add-in stiKeynotes.com does the trick and allows to export all keynotes (whether annotated somewhere or not) into a text file. If the text file is not there (and it is not judging from your description), there is a fallback folder.
Message 17 of 22
jimbell153
When I downloaded and started to install https://stikeynotes.com/ I got the message:
Microsoft Defender SmartScreen prevented an unrecognized app from starting. Running this app might put your PC at risk.
Have you experienced this?
Message 18 of 22
MiWolff
I routinely check everything I download from the web with the anti virus app (mcaffee) installed on my machine. If that gives me a thumbs up, I use the piece. I think in this case, Windows considers an msi-file to be fishy. Best luck!
Message 19 of 22
jimbell153
Message 20 of 22
MiWolff
Yes, I got the same message when I tried installing the add-in with Revit running in the bg. When I restarted Revit everything worked out.
