Missing grids in 3D view - Revit 2019
Message 1 of 15
I'm trying to figure out grids don't show up in 3D view?
Please take a look at the attached model!
Regards!
Replies (14)
Message 2 of 15
They don't. Only levels show in 3D view for now.
Message 3 of 15
Atafs
I don’t think there is a way to show grid lines in a 3D view!
To work around this:
Option 1:
  1. Select a model line (I recommend you create a new one so you can change its properties later on if needed)
  2. Trace over the existing grid lines and bubbles.
  3. Use Model Text from the Model tab to place numbers in the grid bubbles.
Then you will be able to see a representation of the grid lines in your 3D view.
Option 2:
This involves dynamo, have a look on this video
Search in YouTube for ''Revit 3D Grid''
https://www.youtube.com/watch?v=c6etYmwLi4o
I hope this helps
Ataf Sakhri
Message 4 of 15
Viveka_CD
Hi @Anonymous
Please vote for a similar idea on grids in 3D view
See a workaround in this thread
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Message 5 of 15
Thanks!
....cannot believe revit doesn't show grids in 3D.....seams something so trivial to me....
Regards!
Message 6 of 15
You can combine the suggestion above with an in place mass if you want to show the grids as true 3D planes.
Message 7 of 15
Viveka_CD
@Anonymous I see what you are saying!
The best thing I can do for now is to ask you to vote for the existing idea and add your comments there!
Lets hope this will be on its way!:)
Message 8 of 15
RobDraw
Grid lines in 3D sounds like a graphics faux paus.
Rob
Message 9 of 15
Brilliant idea! Though, a faster method would have made more sense.
Message 10 of 15
hanslammerts
Typical Autodesk approach.
First let them buy 3D levels.  Develop 3D grids for the next release.
tumbs down
Message 11 of 15
RobDraw
tumbs down
How is that helpful?
Rob
Message 12 of 15
hanslammerts
Same reason why anybody would like to see levels or any other annotations in 3D. Are you now working for the a team helpdesk Rob Draw?
Ps  forum is mobile incompatible btw. It sucks. Nothing new.
Message 13 of 15
RobDraw
Do you really need to constantly bash Autodesk in their own forum?
Not helpful at all and annoying at best.
Rob
Message 14 of 15
hanslammerts
Only if you keep throwing me your silly questions.
Message 15 of 15
Viveka_CD
Gentlemen,
Please vote for this idea on grids in 3D view
Add relevant comments as to why this idea should be implemented on the Ideas thread. There is a dedicated team looking at the ideas, and your comments will support the path to implementation.
