Missing Elevation Markers?
20 REPLIES 20
Message 1 of 21
64945 Views, 20 Replies
two of my elevation markers (North and East) have disappeared. The actual elevations are still visible and fully functional, but their tags have disappeared. "Elevations" is turned on in the View Properties dialog, but only 2 tags appear.
Anyone know how to get them back?
20 REPLIES 20
Message 21 of 21
laura.johanssonPN37Y
I don't know if this will help somebody but 2 of my elevations disappeared because somebody changed the Elevation type to something else. I had to open a working view where ALL elevation markers were visible and locate the stray ones and when I selected the elevation markers I could see they were a different type. When I changed back then everything was fine and dandy. Everything else between the elevations were identical (as they all had templates applied to them), apart from the type which I couldn't see until I went into a working view. Hope this helps.
Forma Design Contest
