I don't know if this will help somebody but 2 of my elevations disappeared because somebody changed the Elevation type to something else. I had to open a working view where ALL elevation markers were visible and locate the stray ones and when I selected the elevation markers I could see they were a different type. When I changed back then everything was fine and dandy. Everything else between the elevations were identical (as they all had templates applied to them), apart from the type which I couldn't see until I went into a working view. Hope this helps.
