Hi @Anonymous, @Anonymous, @Anonymous, @Anonymous, @Anonymous ,@adam.m.nelson and @Anonymous
With quite a few customers reporting the same issue, I'm trying to gather information, compile and send a report to Microsoft as well as system specifications team at Autodesk to dive in. Please try to answer so we can focus on resolving
If you can send me screenshots, NFO files, journals that would help. I can share private folders for each.Let me know.
I've heard back from @Anonymous but I'm waiting for your specific responses see below, to compile this report:
@Anonymous
System specs: A 512GB surface book with intel core i7 processor and 16GB RAM memory and Nvidia GeForce 965M 2GB GDDRS memory
Issues: Keyboard glitches when using any tool in Revit 2017 whether it is Rendering, line tools or placing a wall.
Keyboard freezes every 5-10 minutes only when working on Revit
Issue resolved: After installing and working in Revit 2018 resulted in no glitches
Other programs installed? Does the issue occur when running other applications?
@Anonymous
System specs: Microsoft Surface Book with the performance package. Can you send more details specs or provide a link?
Also, which version of Revit are you using?
Issues: Keyboard glitching occasionally, but once glitch occurs doesn't seem to go back to normal.
Tried: 1) changing the resolution to correct visual glitching, but still, continues to face keyboard issues
2) Updated keyboard drivers but issue persists
Other programs installed: SketchUp and AutoCAD (no keyboard glitch when running these applications, only with Revit)
@Anonymous
System specs?
Revit version?
Issues: sporadically disconnecting/frozen keyboard and mouse.
Tried: 1) To fix it a few times by closing the screen, resetting etc. but now that doesn't work and it doesn't detect the keyboard or mouse despite being able to attach and unattach. ( Are you talking about the keyboard being attached or a program tool?)
What are the other recommendations that you have tried? Can you provide links to help the community seeking similar solutions?
@Anonymous
System specs: surface laptop - specs?
Revit version?
Tried: A RAM cleaner for heavy projects
@adam.m.nelson
system specs: Performance package with certified CPU/Ram/video card
Revit version:?
Other apps?
@Anonymous
systems specs?
Revit version?
other apps?
Issues: keyboard glitches
Tried: External keyboard seems to work
@Anonymous
system specs: Surface Pro3 detail required?
Tried: reinstalling keyboard, does not work
Issue: Reopen Revit every 10 minutes (Does Revit crash? or you are having only a keyboard issue) Please elaborate?
Other applications?
@Anonymous
system specs: a refurbished surface book with i7 processor, 18 gb, 512 gb, NVIDIA (more details required)
Revit version?
Issue: Revit doing same things (please elaborate). Wouldn't let me type, delete.
When the browser (which browser) is open, does your application freeze?
Other applications?
NOTE: Please check out the other threads related to this issue:
1)Surface Book Problem with Keyboard/Trackpad when using Revit 2016, 2017
2)Microsoft Surface Book Keyboard issues with Revit 2017
3)Revit with Surface Book
4)Revit Scaling issue on surface book
5)Microsoft Surface Book Revit 2014, 2015 & 2016 problem
6)Surface Book Issues
7)Student using Revit 2017 on Windows Surface Book
Looking forward to your responses. Let me know if you have additional questions.
