Measurement in 3D model
Message 1 of 9
Hi, I want measure as per attached photo (the 3D surface and model line). I know this is sample thing. But i dont get snap for 3D surface although i try to on snap . Anyone pls suggest me why i dont get it. Thanks.
Replies (8)
Message 2 of 9
Samantha-G
Hi @Anonymous ,
Are you not able to get the measurement in plan view?  Another option would be to place a dimension, I was able to place a dimension but I could not use the distance command at all in 3d.
Sam G, CM-BIM
Revit Certified Professional
Message 3 of 9
constantin.stroescu
  • is Model Line  placed in Plane parallel to the Plane on which is placed the Extruded Model?
  • is the Model Line parallel with the Edge (Vertical Face) of the Solid ? If not , you can not put dimension unless you do it by clicking an End Point from the Model Line and the the Vertical Face of the Solid,
  • but , maybe the Solid is not a vertical Extrusion but a tapered form. In this case , draw a vertical Reference plane on the side of it snapping on the edge, and you will be able to dimension and measure
Constantin Stroescu
Message 4 of 9
Do you know how to set the Work Plane? That's your first step.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 5 of 9
Hi, i already tried by setting up work plane. not settle yet. I think the main problem is that i m trying to measure solid surface's edge of cross section. is it possible to get snap solid surface's edge of cross section?Thanks.
For your reference, u can find revit file from link.
https://www.dropbox.com/s/o85lp37l0rn9znh/CBW%20As%20Built.rvt?dl=0
Message 6 of 9
Yes the model line is parallel with edge and the solid is extrusion with tapered form. i tried with vertical reference plan but didnt get yet. For your reference, you can find revit file from the link. Thanks.
Message 7 of 9
bin
It looks like the face of the generic model is not flat.
Message 8 of 9
yes. i decide to export to cad and measure.
Message 9 of 9
GraphOnto
Vote in the forum link below to signal your obvious and basic need for measurement functionality Revit 3D views:
 https://forums.autodesk.com/t5/revit-ideas/measure-in-3d/idi-p/6336588
Cynical quip
