Hi fellas!
I want to include rooms so that they show up as ifc spaces, but I also want to exclude areas from showing up as IFC spaces. Is this possible?
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
You can set in the IFC Options (File > Export > options > (all the way down) IFC options) the Areas from IfcSpace to "Not Exported". That would do the trick.
Warning: I have had bad experience with modifying the IFC options, after editing all categories that weren't defined before now all became "Not Exported", and the resulting IFC was missing elements.
I no longer edit the IFC options (Once setup and left alone)
Alternative: Add a Parameter IfcExportAs as a project parameter (instance) to the Category Area (and maybe rooms)
If you give it a value of "DONTEXPORT" it will never export.
I've written a small app for it, and is based on the visibility of Worksets, if the workset of the room/area is visible in the active view the IfcExportAs = "", Else "DONTEXPORT"
So I can export multiple parts of a building with their rooms only, or leave Area's out all together
- Michel
@TripleM-Dev.net wrote:Hi,
- Michel
I used your alternative, selected all areas in the model and added "DONTEXPORT". Worked great!
