Model dubble-curvature beam
2 ANTWORTEN 2
Nachricht 1 von 3
georgetoneverland
554 Aufrufe, 2 Antworten
Hi! My first post here.
I want to model some beams like ones attached below, so curved in plan but also in elevation.
Is it possible to model and rebar it in a clean way?
2 ANTWORTEN 2
Nachricht 2 von 3
You can do it in several ways , but I think the more appropriate one is to create a Sweep:
  • first create a curved Wall that has the desired curvature in Horizontal Projection of the Beam
  • then create a Roof by Extrusion that has the curvature of the Beam in Vertical Projection
  • Attach the Wall ( Top) to the Roof
  • Create then, a Component Model in Place>Structural Frame>Sweep . Pick the intersection line (Wall/Roof) to be the Path and choose the appropriate beam section Profile previously loaded.
  • The Sweeped Beam will have a double curvature now.
Constantin Stroescu
Nachricht 3 von 3
The result:
...and the screencast that shows the steps:
note:in my screencast, as I had no appropriate Profiles loaded , I had to make a custom rectangle profile for the Sweep.
https://knowledge.autodesk.com/community/screencast/56b19974-77f6-4d1c-91a5-a91bf22c0eff
Constantin Stroescu
