materials
1 REPLY 1
162 Views, 1 Reply
materials
Hey guys,
I am changing the materials in my revit design so I can use the render online but for some reason when I change my materials for one object it will either only change the preveous objects matrials or change two seporate objects matrials.
Don't know whats wrong. Has anyone else had this problem?
What can I do to fix this?
1 REPLY 1
The most common cause of this is not duplicating the Appearance Asset as well. If both the original material, and duplicated material use the same Appearance Asset, any changes made to that Asset in the duplicated material will also show up in the original.
Please see the a folllowing post which should fully explain this process and solve your issue.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Smiley Happy
Forma Design Contest
Technology Administrators
