interface view problem
Hi everyone,
 any ideas how to solve this mess?!?
ennujozlagam
Hello, have you tried to untick use hardware acceleration from options > graphics . 2nd options is to change window display setting to 150% - 200%. If this works for you. Thanks
thanks for the answer but neither of both solutions work
Unbelievable .. the problem is Windows 8 and the window transparency options.
If I decrease the brightness/increase the darkness, the buttons appear but the filename disappears ...Smiley Frustrated
ennujozlagam
hello, try to update windows with service packs and install latest autodesk updates if this one can help. thanks
I have seen similar problems with AutoCAD and Revit. As you have discovered its the transparency interface of windows. Despite having all the lastest updates, it still saw it on some machines. I always turn off aero theme and then everything works.
