Frame of Window not displaying
Message 1 of 12
Hi all. The window frame is not displaying in the plans as per the image attached. I checked in visibility and it seems to be ok. Any ideas? Thanks
Accepted solutions (3)
Replies (11)
Message 2 of 12
diegoaev
where did you get this windows and how was it created?
can you see the frame if you open reveal hidden (RH)?
is the frame on the elevation?
It could a object style issue.
Message 3 of 12
mp_thompson
The window looks dashed to me, have you inserted it in the wrong phase?
Select the window and check the phases under your properties.
www.thompsonarchitecture.co.uk
Message 4 of 12
Hi @diegoaev
I got them from Shuecco.
Yes, I can see it when I open reveal but cannot pick it up to select unhide element.
Yes, frame is on elevation.
Message 5 of 12
@mp_thompson
phase is new construction.
i attach file.
thanks.
Message 6 of 12
mp_thompson
Thanks @Anonymous it's the window family.
The window frame under fine visibility settings is an imported DWG, imported DWG visibility was switched off in your main model.
Under your visibility graphics (VV for keyboard shortcut, then Imported Catagories tab) switch Imports in families on.
Message 7 of 12
diegoaev
The window family is using CAD detail sfor the frame, so you had to show the import categories that came with that.
Let me know if you needed more help, if not check this as asnwered.
Message 8 of 12
mp_thompson
Jynx @diegoaev !
Message 9 of 12
diegoaev
Some of us have to work!! hahahaah good deal @mp_thompson
Message 10 of 12
Thanks!
I noticed that some windows have glazing closer to the exterior than others, please find image attached. Is there any way to swipe it?
Message 11 of 12
mp_thompson
You're welcome @Anonymous
The window reveal/setback can be adjusted with with the 'Window Wallaxis Position' Parameter
Message 12 of 12
mp_thompson
I was on my lunch @diegoaev ! Smiley Very Happy
