Material Takeoff Schedule to show Basic Wall Assembly
19 REPLIES 19
Message 1 of 20
daniel.jolivet
1317 Views, 19 Replies
Working in Revit 2021:
I am trying to use the material takeoff schedule tool to create a construction assembly for each wall type.  I have most of it working, but noticed that multiples of materials in the assembly are only showing up once.  See screenshot:
I have the "Itemize Every Instance" box checked in the sorting/grouping window, but that does not seem to make a difference:
The only workaround I have been able to come up with is to make a new material for where I have double layers in the assembly and use the comment section to describe the intent, but this does not solve when I have separate layers of the same material (on either side of a typ stud gwb for instance only one layer of gwb shows up).
Would it really be too hard for Revit to just give me this exact information as a schedule as I created the project walls?
@ToanDN - your solutions have saved me before.
Labels (3)
19 REPLIES 19
Message 2 of 20
in reply to: daniel.jolivet
Create Parts and schedule Parts.
Message 3 of 20
Duplicate Material: Marks?  Filter?
Message 4 of 20
Thank you for taking the time to look at this.  I have done as @ToanDN  recommended, but I now see that the only material information available in the Parts schedule is the title of the material.  Is there a way to pull the takeoff material schedule fields into the parts schedule?
Further: is there a way of indicating the "layer" number as a field as shown in the edit assembly window?
Thank you @barthbradley for also looking at this.
Cheers.
Message 5 of 20
I am not sure how to do what you are suggesting.
Message 6 of 20
My understanding is that the MTO was inaccurate. I would immediately suspect a Filter is the culprit if it were me.  Maybe I misunderstood.  Dunno. But Wall MTOs are pretty fool-proof.
Message 7 of 20
I see, thank you @Anonymous. I will check the filters again and restart the program to make sure its not some gremlin.
Message 8 of 20
Just to be clear, I'm talking about schedule filters.
Message 9 of 20
Yes, thank you, that is where I am looking.
Would you do me a quick favour and try adding a couple layers of GWB to your assembly and then showing that the schedule shows the multiple layers on your schedule? It seems like a simple thing that is just not working for me.
Message 10 of 20
Cheers.
Message 11 of 20
Message 12 of 20
daniel.jolivet
in reply to: ToanDN
@ToanDN thank you!  I see that I was using the Parts schedule, not the Material Takeoff Parts schedule.
Update: I do not have the option for a Layer Index Field:
Thank you.
Message 13 of 20
Thank you.
I use 2022, which version you are using?  By the way you don't need it because the schedule still shows separate layers of the same material.
Message 14 of 20
daniel.jolivet
in reply to: ToanDN
I am using Revit 2021, this might be the difference.
Even when I just do the Multi Category Material Takeoff I do not see Layer Index as an optional Field.
Message 15 of 20
Don't worry about it then.  You don't need it.
Message 16 of 20
What do you mean by Layer Index?
Schedules count things.  Layer Index not a "thing" in Revit.
Message 17 of 20
clipped from @ToanDN above:
 Cheers.
Message 18 of 20
My bad.  Not following the discussion too well. I see now you are talking about Parts.  Sorry about that Chief.
Message 19 of 20
No worries, I am learning here.
Thank you!
Message 20 of 20
daniel.jolivet
in reply to: ToanDN
Thanks for the support, I will run with this for now.
Cheers!
